configure dos-protect interval
configure dos-protect interval seconds
Description
Configures the denial of service protection interval.
Syntax Description
seconds Specifies how often the DoS protection counter is monitored.
Default
The default is one second.
Usage Guidelines
This command configures how often the DoS protection counter is monitored.
This example sets the interval to 5 seconds:
configure dos-protect interval 5
This command was first available in ExtremeXOS 11.1.
Platform Availability
